…Your killing me man,
I’m paying out of pocket now but I’ll make it back in a couple strong weeks maybe 3 weeks at most.
Ok I’m so confused what is wrong with the machines you have? Are you really at the point when buying a bigger machine makes financial sense.
It gives me more energy to do better stronger more relatable work. My LCC is purchasing it anyway not me. At Space Clean we pride ourselves in having the Highest level of top grade professional equipment and expertise.
Because of Space size and weight; we are planning to order this bad boy with a separate heater unit. Space and weight, space and weight… thought on this
Who opened the flood gates. Sheer lunacy.
Oh ok well you clean anything you want with that machine. I’m assuming space is limited because you have a big tank to pull around to feed that thing.
Your customers don’t care about your equioment the vast majority of the time. They just want a good job.
The insane asylum is being over ran,and all the patients have the keys.
Is there an English translation for this?
Yes. But im gonna be nice,because it’s day…
I need to get me an LCC if it’s going around buying pw equipment to hand out for free.
Those LCC’s are only for the super elite washing contractors. We don’t qualify.
You should look at the slim line skids if you need space saving. I wish I would have.
S Corp?
I’m an LLC. The space planet guy is a LCC. Lol
If you end up doing the simease kit like me, don’t. You sound like you are gonna be using the 8 more than the two 4’s. I got the kit to cut corners and have a backup plan in case something goes wrong. Why not just build your own 8 with a predator and udor pump. It’s about 2k and will save you some money, plus those engines have good warrenties.
Do you request to file as an scorp to save on taxes? I got a workman’s comp policy through hiscox and set up payroll with my bank. Roofs are off the table lmao
Yes form WH76317. Allows you to pay 3% of gross income. That 3% can be used for private expenses unrelated to the business if you claim exemption 7158C on your scheduled quarterly installment. @Infinity can probably go in more detail to help this budding entrepreneur
