Just wondering what type of set up you guys are running for 8 gallon per minute set ups for the incoming water source and filters
I ran 1-1/2" pvc as far as possible with a Banjo y-type filter. At the end it tees into two 1" hoses that double feed my pump. (they need to be rated for suction so they don’t collapse)
Also, if you search “8 GPM plumbing” “buffer tank plumbing” “truck setups” & “trailer setups” you’ll get some great advice and insight from guys who have posted info about this in the past.
