Is it possible to put this Landa 6gpm pump on my 4.5gpm machine? If so, how?
Same pulley sheave might work but call udor top make sure 18007322670
Is udor the same company? Or do they just have the information I need.
Btw this 6gpm pump is coming off of that 3phase unit I posted about. I’m not sure if it makes any difference
Udor is ego makes the pump. They will know what rpm and sheave it needs. Jave the pump model and rpm of your machine when you call. Probably 3k or 3.6k
On the elect motor that you are taking the pump off of, it should also have a sticker with HP, RPM on it…
He is putting it on a gas motor i believe so he will need those specs. Heck. Hook it up as is and see what happens. Adjust the unloader til you have a few drops of bypass and see what you pressure and gpm are
If his electric motor says it runs at 3600 rpm (or what ever) then he has the answer to his question.
I believe he is putting it on a gas engine. He needs rpm for that
IBS is correct. Putting the 6gpm on the gas engine. I’m just not too familiar with pulley ratios and stuff
