I got a 5 gallon bucket and turned my pressure washer on to see if it is actually filling up 5 gallons a min. I set the timer and the bucket was overflowing before 50 seconds. I’m not complaining about the extra power but is there something that I am doing to have it overwork like that?
Most any pump will do that. Put a pressure tip in rated for your max psi advertised on the pump and see what your gpm is. That’s a true bucket test
Also if you have an injector in-line it will also add to the total volume
Thank you. Ill test it this evening
