I have 3500 maybe $4,000 set aside to buy my first pressure washer for my startup business. I can either spend the whole 4000 on a smaller hot water pressure washer with about four gallons per minute or I can spend it on a high gallon per minute cold water machine what are your thoughts on this?
What will u be doing?
I want most options on the table. Fleet residential heavy equipment commercial etc.
May have just answered your own question. Hot water needed or useful for everything you mentioned, residential not as much.
I want to start with an easy Kleen 3.5 gpm 4000 psi its not a lot of water but its HOT . So…?
Keep reading the forum, your highest investment right now is your time, take notes, bookmark and use the search function in the top right of you have questions.
Read read read read read, the PWRA.
