Do any of you pw light poles? If you do, do you use a telescopic wand to reach top? I’m guessing around 25’. Trying to figure out best way to do 76 light poles at a hospital and there will be cars and trees in some areas.
Just replied to your post on FB, but I’ll repost for the benefit of anyone who has avoided that massive timesuck:
Hmm, depending on the size and shape of the poles, maybe use an exhaust stack brush for truck cleaning? Could put it on a wfp, use a pump sprayer attached to some 5/16” tubing to apply your detergent directly to the brush, and then rinse off with your pressure washer. Any overspray should be greatly diluted that way.
…Now that I think of it, an exhaust stack brush probably would’ve been perfect for cleaning some columns at a bank recently.
