what would you recommed for 2 stepping?
I assume you are referring to chemicals. We use are aluminum brightener follow by one our standard truck wash soap (R109 or V505).
Hey guys, Im Working on a fleet wash contract of 14 busses and the location I will be washing can’t have anything down the drains so I will be reclaiming my water.
My question to you all is, if I 2 step how will that work for reusing my water week after week out of my 300 gallon tank? Or should I just brush them instead. Anybody have any feed back?
It takes a considerable amount of filtering to be able to reuse your wash water for truck washing. I recommend capturing it and disposing of it to the sanitary sewer.
Samsung Note II using Tapatalk
Ok great. And with the 2 step process do I have to be worried about what’s going down the Sani sewer or will the city come after me at all for the acid and alkaline ?
If two stepping, check your PH to be sure it is within the limits they accept. I also recommend just making sure what you are doing in that area is an acceptable practice with the local authority.
I’d recommend using high pressure, hot, alkaline detergent, and skipping the acid.
Do you know the PH ranges for 2 stepping?
