i purchased the northstar 5.5gpm bleach pump. It already has one fuse the goes to the pump but i’m not sure if tha protects the motor also or i need to add another by the battery?
The one that comes on it all you need
How do you like the unit so far? I purchased one, it’s on BO, anxious to get it!
I’ve just played around with it but it’s nice. it’s got the power switch and fuse already on it so you just need to run your power and ground lines to it. I’m not sure how i feel about the quick disconnect fittings. It came with 3/4" Od for 3/4" Id hose which I’m not using so I ordered the Jabsco Flojet 1/2" from amazon but they didn’t quite fit. I had to sand down the ring at the end that is use for the slide lock with a power dremel so i can push it all the way in and lock it in . take off the o ring if you do this just in case . Now we are good to go. I would probably get the 1/2" fittings that are made for it from northern tool and extras.
thanks for replying
