Is their any given time to waterproof a deck after being stripped.
Yes. Make sure the deck has had time to dry thoroughly. Make sure the weather is predicted to be nice so it can cure. Check the sealer you are using and make sure you apply it when the temperature is above the recommended temperature. Why are you asking this on a pressure washing forum by the way?
