Landa Hot water pressure washer Gas Powered/Diesel Heated
Belt drive landa pump w/7year warranty
Hanguard electric start
Schedule 80 hewating coil with stainless top wrap
4.7 gpm 3500 psi
50ft. high pressure hose
trigger gun, wand, nozzles
Total = $5,995
OR
Water cannon website
Hot Water-Honda GX 630-Key Start-8GPM-3500 psi
• Hot water pressure washer with 118 degree F temperature rise
• 20 amp charging system
• Super skid stationary platform
• Rugged steel, low-profile frame with powder coated finish
• 48"L x 40"W x 41"H frame dimensions offer versatile installation
• Super efficient schedule 80 coil (coil is prorated)
• Stainless steel coil wrap, burner hood, and control panel
• 15 gallon poly diesel and gasoline fuel tanks with fuel filters
• Reliable Honda or Subaru gasoline commercial/industrial electric start engine
• Includes 12 volt burner and marine duty battery box
• Fully self-contained, no external power required
• Choice of reliable Cat and General pumps
• 3VX belt system offers balanced power transfer
• Engine and pump oil drains offer easy maintenance
• Safety pressure relief valve
• Reliable Beckett burners
• Adjustable thermostat
Standard Accessories
• 50’ hose
• Down stream chemical injector
• 4 color-coded QC spray nozzles
• 1 color-coded QC chemical nozzle
19H19
Total $6,509
