Hi guys,
I’m looking to set up an enclosed trailer and I was wondering where to put my waterfed purifier machine. Do I put it before the tank so all the water in the tank is pure? Or After the tank?
Thank you!!
Hi guys,
Thank you!!
Depends
Will you be doing pressure washing also?
What is the flow rating of your “purifier”?
Putting the purification before the tank allows you to get away with a smaller (read low flow) purifier because you can just fill the tank all night and use water from it during the day.
If you put the system after the tank it better have a pump to produce its own water pressure, and it better be up to the task of purifying enough water to keep up with your pole. this is the way I do it because my system is portable for those difficult to get to jobs. Simple as that
Sorry for the late rey I haven’t logged in in a while… I think I’ll add purifiers before entering the tank and then connect my waterfed system afterwards.
Is that okay?
