Somebody fill me in I have had 3 big houses this week driveway patio…
These driveways were dirty so I get finished washing then I got to Rense all of the drive way. there is so much dirt in pockets.
All i got is that turbo nozzle to rense back and forth.
It just don’t do a good job I have to go back over and over. Now I get a good rain which suppose to tonight and will wash it clean…
What is a way or something to get that can do a good job to rense to drive way? I know somebody has a trick to do a good job…
Whats your GPM?
The more the better, if your on the lower side than its just going to take longer until you get more gpm.
Also a turbo is slower than just using a fan tip
@Racer that could also be done, I just figured if he already has a female end on the hose then any other implements would have male ends, so changing the hose end would mean changing all the other ends.
I use a blower to remove majority of loose debris first. After that i use a 28" surface cleaner to remove the debris from concrete ( porous material). Then i rinse the debris brought to surface off of the driveway with 40 degree fan tip. Works very well and looks amazing.
I had a job today and I had to of blown out 2 or 3 orings. Anyone had any good ideas on keeping those suckers in there. Luckily I found 2 out of 3 of them. Am I doing something wrong or is this a common issue.
