How often do you use a surface cleaner on a deck to clean it .( raw wood )
Are you good enough to clean a deck ( raw wood ) with a surface cleaner and make it look like you cleaned it with a gun and NO stop marks ?
Never.
I cleaned a deck with my classic looked GREAT… I used my gun on the rails and it ruffed them up had to sand it smooth… used a blaster should have used the yellow tip…
I pay attention to the grain of the wood too. That helps. I sometimes use a rinse tip with no chemicals to just sample water, this way it won’t fade.
If the deck I raw wood I offer a price for staining suggest guttering if the have none, and tree , foliage trimming to allow sunlight to help keep the surface dry. I also offer them an annual rate before a close holiday , like “Labor Day”.
