Hey y’all. I’m new to this so excuse me if this is a stupid question!
I have a 4300psi and 4gpm pressure washer. I’m currently trying to figure out what surface cleaner I should buy.
Most of the surface cleaners I seem to want are 4000psi. Will this be a problem with my pressure washer?
If it is, what surface cleaner would you recommend for me? I’m thinking 18 to 20 inch and in the $600 range.
Thanks in advance.
Either will work with your washer. I’d go with the 20" SC
Depending on what surface you are cleaning…I would not think that you would be running that cleaner at 4300psi…would probably be down there around 2000-2500psi…unless you are doing mostly commercial work.
Im trying to learn also, so the surface cleaner will push out 4000psi if needed and your machine can produce, but for residential you need to have the right tips in for lower psi in the 2000-2500 range?
Thanks
