What size of electric motor do I need for a triplex pump that came with a 20 ho Honda engine. The gearbox has a 1" shaft input
There isn’t any numbers on the pump itself. The numbers 31.1256.09 with the letter B inside a square are stamped on the gearbox is the only thing on the pump
