Pump maintanance
Hi out there. Less than 6 months in the biz but have general question. I have a Landa 3500psi 4.7 GPM hot water machine. Generally is there anything that I need to run thru pump after jobs to keep it running
smoothly? I downstream all chemicals so nothing like that goes thru pump. Thx!!
Change your pump oil every 1000 hours if it is a Landa/karcher or Udor and you should be good. If it is a general or cat pump then just pray a lot.
