Hello all. I just upgraded my pump, from an AR 3000psi/3.0gpm to an AR 4000psi/4.0gpm. Love this brand new pump, everything runs much nicer now.
My question is, should I get new nozzles for my wand, that are rated for the added gpm/psi, or not even bother. Thanks.
What size tips were you using before? If they were rated to produce 3k psi, they will not be the tips for 4k psi
It’s the tips that came with the original pump setup. I guess I better order up some 4000psi tips.
