Moss....strong roof mix?
I was going to go with a strong roof mix, let it dwell, then hit it with the surface cleaner… first time attacking moss like this…so to the customer…as like the roof…do I tell them the moss will fall off with rain fall…an to everyone have a Happy Memorial day weekend!!!
Is this on the roof?
If on the the roof i would do a 50/50 roof mix and leave it. You might want to hit it twice to make sure the moss is dead which means it will turn white.
I have pictures but can’t figure out how to do it on the phone
Na it’s not on the roof…
When creating a post, you should see a small text link in the bottom right corner of the screen that says “upload”
50/50 SH mix with a little bit of caustic added to the mix, Leave it for 2 days and than come back with the surface cleaner. Once clean re spray with the 50/50 mix to stop re growth.
Hope that helps
Troy
Wash Rite NZ
www.washrite.co.nz
Got you…thanks for responding…came out great and they loved it…
Looks great! Not sure i would have used the SH mix. I would have power washed and then spray with mix like Troy said. Point being to keep your cost down for more profit. Just a thought. Good job man
Jonathan Zarzour
Xtreme Cleanz
Birmingham Alabama
Ok…I’m hearing you…yeah just starting out…learning an always willing to…thank you
Beautiful results. I am new to this and have a question:
Is there a danger of your wash killing the grass adjacent to the walk, or is there a way to prevent that?
Thanks
Absolutely, you have to keep everything watered down. I have burnt several plants and grass
Xtreme Cleanz
Birmingham Alabama
