I have a customer next week that spilt home interior paint on his drive way. What would be the best way for me to have it looking new?
What kind of driveway?
Latex paint will melt off with hot water. I’ve heard it’s gotta be pretty hot, though.
Sorry i didn’t mention but it is a concrete drive way. I only have a cold water, pressure washer. should i still take the job?
Concrete
@DR.Pressure Rent a hot water machine AND a surface cleaner in combination with a chemical or you’ll be there a month of Sundays with a fan tip and a cold water machine and probably still won’t get a result you’re satisfied with.
Thanks a lot for the suggestions. Great to have the help when you need it.
No need for heat. Acrylistrip from Eacochem will take it right up. Apply, brush in, dwell, power wash off. Repeat until it’s gone.
http://www.eacochem.com/ProductDetails/productDetails_AcryliStrip.htm
Or “Nock Off” from Southern Stain and Seal.
