Install unloader bypass - advice needed
Question about my unloader: I just got a tank and I want to install a bypass from my unloader to the tank. From everything I’ve seen and watched, looks like all I have to do is disconnect the bottom part of the hose and run it all the way to my tank (as well as plug the hole. Am I right?
run the top one to the tank and plug the bottom one
Thanks! I have about 80% done. I need to connect the plumbing from the buffer tank all the way to the pump inlet.
your welcome!
