How do you clean pavers with a surface cleaner?
How do clean pavers with a surface. Cleaner?
I don’t.
Do you just pressure wash with a gun?
I don’t clean pavers. At least not the one set in sand or that are uneven.
I haven’t done any papers but I think you can clean as usual…but I would think now matter how it was done you would have to resand the joints after they dried
I use my Surface Cleaner. I turn the throttle down on my pump to reduce the pressure. Depending on how solid the joints are, I discuss new sand up front.
Pumps don’t have throttles. Air cooled engines are designed to be run wide open. Change your nozzles if you want to lower pressure. I have found it is easiest to turn down any work that causes headaches.
If they’re flat, you can surface clean, but I never clean them without up-selling the re-sand and seal. All depends on how even they are and if the customer is prepared to sand.
We use a wand when we clean pavers in a small area.
