After installing the new pump with new unlaoder valve I started it but no water is coming out.
I tried open outlet port there is no water at all. The water feed is ok and installation is same as the old one.
Might be a left hand pump
Thank you
I solved it, I had to prime water in outlet port
How did you prime the pump?
By feeding the outlet port by external water hose
Durrr
