Help lost my 0 degree tip
Pls help. I lost my trust Red zoro degree tip but I found these things. They produce hardly any pressure tho??
What do they do. Can someone quickly tell me how to wash with low pressure like you lot do? I’m half way thru anjob and I have to finish it today. Needs some rent $$ for the caravan.
Can I jam a screw inside the holes to increase the pressure or somethin?
thanks guys
Drop them in the dirt and step on them. Encrusted dirt will help increase pressure. Higher the better.
Also, poke dirt into the holes with a toothpick. Half clog them to increase pressure. Small pebbles work as well.
DOBNH 0052-M
Put your thumb on the end to increase pressure
You have just bested us all. That may very well be the best post this year
That dolphin clearly has a low pressure tip installed.
I have low pressure tips. They suck. I want high pressure tips.
I like dolphins… but not that one… not today :frowning:
eeeewww, is that a Kohler?
Nope lol it’s a honda
Buzz has an electric karcher. He has a tendency to photoshop other equipment into his posts
Whew…lol
