I was due for a new chemical injector, and I finally added an aluminum rod to keep the pick up filter at the bottom… Long over due, but this should keep me from going
back to the trailer to check that it’s still picking up chems.
That is a good start.
But use a pvc pipe and run the hose through it.
And get a metal restrainer the one you have there has a thin film mesh, th at will disolve after a couple of uses and could affect your chem injector
Ok!
Any pictures? To get a better idea
Look at this on eBay
I use these
But wiith a 1/4 barb connector to the hose
