Hey is it possible to run 2 pressure washers from the same house just from different spickets?
If they are both 2.5 gpm I don’t see why not …more than that I would say no
Yep. But in that case, you’d be better off getting one bigger machine than running two pea-shooters.
You can put a T after the machine but before the hoses and run two hoses that way. Of course you’ll only have half the psi/ hpm per hose but ss long as you’re not cleaning concrete it shouldn’t be too much of an issue.
