So I messed up and used the wrong chemicals in my house wash mix. The house wall is all damaged and has weird drip lines stained into the paint.
The customer is sooo angry and I need to fix this ASAP.
I can get cheap paint from a buddy. Can I run paint thru my downstream injector instead of paying a painter? There’s way too much damage to fix it with a paint brush. Downstreaming paint would be fast like a spray gun, right???
What chemical did you spray on the house? And ask your buddy with the cheap paint if he knows where to get a cheap sprayer… although you may be beyond the repair stage and into the replace stage depending on the chem
Don’t use an xjet for paint they clog up. Use a rotary nozzle, it actually mixes the paint as it sprays it. If you use oil based paint it will lube up your PW pump for winter…
Hey Greg good to hear from someone with some actual experience with this problem. Thanks mate.
So if I use oil based paint via downstream injector… will the rotary nozzle mix it up enough? Or will it separate when it hits the house and go streaky.
