Hello.
My pressure washer is only a 2.5 gpm washer. I know it is low gpm.
It has a soap siphon hose that is connected to the pump. Although the manual says not to use bleach , my question is can I add a separate downstream inject after the pump?
I am sure I would Need to cap off the soap siphon that is on the pump.
Hope this makes sense. Please help.
Much appreciated
If you’re using original hose and gun, they won’t hold up to SH. They are built to the same standard. Put some viton o-rings in there and maybe you can make it work for more than 2 days, but you’re going to have to upgrade.
Hey Steve.
Thanks for the info.
I ordered the DS injector and am looking forward to putting it to use,
My next question would be , what gun could I upgrade to?
Or could I use a ball valve wand that I have seen guys use?
Thanks
Much appreciated
