New to these forums, I recently acquired a new machine it’s a Simpson 4000 psi 3.3gpm machine. Questions is, i have replace the chemical injector to a 2.1mm injectior and it’s still not pulling up my solution into the stream, I even put water into the bucket and not pulling it up.
Any ideas?
Yep. You need to do a lot of research here.
