Was reading random threads about unloaders and this and that and read the way to set it up it have trigger pulled start machine and turn till slight srip w 0 degree nozzle on. Well i dont see on my pump where i would pull the bypass hose and watch the drip. Just curious what im missing? Can i onlt achieve that with an external bypass which is hat im thinking and if so where do i install it on this pump?
My question isny how to adust an unloader. Its y i dont have the bypass hose…
Because that pump has a built-in bypass. The section directly under the unloader that goes to the inlet, is your bypass. It just doesn’t accomplish much.
Yea i found a tech article on cats website but wasnt 100% sure i couldnt add an external. Gonna buy an udor to keep on hand for when this cat takes a dump and will have the external on it then. Thanks
