How do you go about cleaning sandstone? Can I use the surface cleaner? I dont want to etch it. I plan on using a hot HW mix. Is a turbo nozzle going to be my best friend for this project? I have a 3500 4.0 GPM
NO surface cleaner, and no turbo.
Just us a 4% + mix and wait, then re apply. You can then do a “light” rinse after
Agree with the above comment. Just get it nice and saturated, increase the dwell time, reapply and repeat, rinse.
Awesome. Thank you for sharing your expertise
Ok. Good to know. Not exactly the same but still a sed. rock, I have a flag stone pool surround to do Friday. I was thinking the surface cleaner could leave gouge marks. Its not that big so I will soak it and use the fan tip J Rod to rinse.
