My title is a little misleading but it’s exactly what I need I just don’t own or ever plan to X jet. I built a 12v softwash rig and I’m injecting Fresh Wash into the supply line so I need a sealed chemical container for it. I have those square footprint 5 gallon chemical pails/containers/ car boys with the threaded caps that have the 3/4" knockout any who you know the ones. Powerwash.com does have a 5 gallon pail “system” with a drop tube but I’m not paying close to $40 for it. Problem is I can’t figure out how to plumb it up lol
3/4" x 1/2" threaded reducing bushing with an internally threaded 1/2" schedule 80 pvc pipe that you thread your 1/4" MPT barb adapter into??? What can I not comprehend here? Thanks for any ideas offered.
I wouldn’t be surprised if they threaded the i.d. AND o.d. of schedule 80 PVC with NPT since they internally threaded one side of their 1/2" x 24" PVC spray wand with NPT so the thicker walled schedule 80 would accept 1/4" NPT quick couplers
$24 for internally threaded schedule 80 PVC pipe??? Pass on that too but good luck to you finding anyone capable of threading PVC for you in NPT lol special machine special cutting fluid yaddy yaaa you know the deal
Thanks so much! I had suspected they did a bit better, I guess not lol The only part I was stuck on was attaching the drop tube and after seeing yours I figure I’ll just adapt my drop tube to 3/4" mpt and screw it into the unused threaded section of the cap.
There’s a guy around here who sells them at the swap meets for $2-$5 depending on condition but they’re used. Had cooking oil in them I believe. I bought a bunch from him but the problem is that he doesn’t always have lids with them
