We have been doing mostly residential pressure washing over the past three years and are finally starting to get some commercial work. Our unit is 3500 psi and 3.5gal. We can rent if we have to… not sure this will be enough power.
We have never attempted to clean anything this dirty before. The manager said they attempted this on their own using bleach and degreaser… not sure if they were using a scrub brush… probably not.
What we have here is some seriously neglected concrete, deep grease stains near the back entrance to the kitchen.
This area is approximately 45’x22’ (Just shy of 1000sqft)
There is a hot water hookup or spicket and I can rent a larger pressure washer. Thanks for the hot water tip. Can you run hot water through any hose or do you need a specific hose? Also would you use a degreaser or some other sort of concrete cleaner? Thanks again
Another concern I would have is how hot is the water going to get coming out of that spicket. I think it’s great that they have a hot water spicket but, I cant imagine its going to get hot enough to break down the grease and oil.
if you run out the hot water tank inside the building —you burn up the elements !! Then you’re out money replacing the hot water tank inside. Something has to heat that water. Assuming there’s a hot water tank inside. Unless the money is extremely good, I steer away from this type of work…
Looks like we will be renting a mobile unit that can heat water up to 200F. They are willing to pay top dollar to get this done. The drain in the back goes into our sewer system so we will have to use something environmentally friendly. Any suggestions?
