Just bought a used WW Classic with a 4 nozzle bar on it. He was running it with an 8 gpm machine and I’m only running a 5 gpm, and with the 4 2502 nozzles on my gauge was only showing about 900psi but was still cleaning my driveway decently and didn’t leave much striping that I could tell. Would it be better to try and get some 25015 nozzles or just plug 2 of the ports so I don’t have to use such small nozzles? Thanks, I know this is fairly basic stuff just wanted to see if anyone had experience with that.
Also got it for $200 which seems like a steal to me lol, he also gave me some simple cherry, and dsr49 which i haven’t heard of but is apparently a wood restorer.
Thanks all for the input, got some plugs tonight at home depot. They only had galvanized steel so hopefully that won’t corrode over time. May try smaller plugs one day but I feel like I’ll be fine with just the 2
Try 4025 tips with it…if pressure is too high go to 1503s. Two 2502s will slow you down and run too high a pressure matching flow to psi will allow machine to hover smoothly across surface and give you fastest production time.
