2 pressure washers more gpm?
Can you take 2 separate pressure washers at say 4 gpm and put out 8 gpm on 1 hose?
Yes. It’s called a siamese kit. You can search that term here or on some of the power wash supply sites for more info.
How have I never thought of this.
Russ Johnson at Southside has them. Maybe some others too. Have to be using pressure trapped unloaders though on both machines.
I am setting up a trailer with a 5.5 gpm and a 4 gpm machine and i would like to use them independently for running 2 guns
and sometimes together for more volume when needed, will i need a 3rd hose reel with a high psi hose when running machines together and is this possible? Thanks
The PSI does not cumulate…the GPM does?
Yes I called Southside today and talked to Russ and he said it’s possible with the Siamese kit
