Do you run a gas powered air compressor or do you have a generator to power it?
Most run Gas air compressor, doesn’t make sense to have two big machines taking up space when you can just have one. Plus the generator you would need to run a big enough cfm compressor would probably cost more than just buying the gas air compressor in the first place
Thats what I figured but ive seen a generator on someones rig and a tank I was curious why. Man those gas ones are high
