Long driveway, water supply?
If your buffer tank is small’ish’ I might just rent a trailer with a larger tank and add that to the price - if that’s an option.
The fact that you are using a buffer tank though, means that you have, in a sense, disconnected yourself from supply issues. If you are able to keep up with the amount your buffer tank holds then you just may wait a little initially. Given it’s flat, taking all things into consideration (hose size, size of buffer) you would have the same issue at 100’ versus 400’ once the flow starts and you have a full buffer.
I just carry a large tank because I have to fill, disconnect, wash, then fill it up again. When I had a smaller buffer tank I had a job with 300’ of hose and never skipped a beat even if I wasn’t off trigger for that long. Just my $.02 FWIW.
I think he only has a 50gal buffer, maybe 100
The 8 being an 8gpm machine?
You got it
Yeah it’s a 50gal vertical. I’m sure things will work out.
I don’t know what GPM he has for a machine. I had a 30 gallon buffer with a 4 GPM machine at the time. Those days are gone with an 8 GPM machine - need a much larger buffer with 8gpm.
how’d it go?
Doing it Monday, I’ll let everyone know.
400’ of supply hose, still had reasonable flow thankfully. I did outrun it a few times but gave me an excuse to take a break. 250’ of pressure hose was about perfect.
4400 sq/ft, three hours.:muscle:t2:
Nice job Chris! Glad it worked out…
Glad to hear it! Hopefully, they’ll call you back (if you want) to do it again now that you’re all set up for it. :+1:
Yeah it’s a relief knowing it still filled my tank at 400’.
Great job Chris!
thanks for the update! So when you run it dry do you just shut the PW down as fast as you can? is it bad for the motor and/or pump to run dry for any time?
I can feel a slight vibration in the surface cleaner when it happens so I just let off the gun and go take a break. The buffer tank circulates the water anyway so I just walk back the 400’ to the truck and shut it down to save gas.
Yea, you don’t want to do this. It is not good for the pump. Spinning parts with no way to cool off don’t stay spinning for long.
Should have brought your fishin pole while you waited
Right??
Sometimes retention ponds and private ponds like this can be home to massive fish! This is from the pond in my neighborhood, shoe is a size 13 for reference :blush:
No kidding. When I lived in Virginia I tossed a line into a retention pond in an industrial area and got a bass just like that.
