65 gallon tank. Sticky means longer to rinse but you can agitate the mix to make it soapier. Pkease get rid of that half inch 2 wire hose. You are killing yourself.
But if it’s runny doesn’t it’s not work as well when you let it dwell on a vertical surface ? And yes I’m going to try and get rid of this hose. I’m hoping to sell it to someone. But I may be the only person to buy something like that. What’s in the black tank that you use?
No one will buy that hose. Black drum was for downstream tank. Small but about all that would fit. Soap from top down and even without surfactant it will clean.
Thank you hope to be as knowledgeable and successful in the buzz as you. Anymore pictures you want to post of your set up I will take.
Rirvin, It’s 99% water and the other 1% is a liquid. Of course it’s going to run. Watch that video I posted on washing with a 8.5 gal machine and see how mine does. Yours should look similar when it’s hitting the surface.
Where do I find this video?
This is probably my favorite no-fuss flatbed setup ever. 8 minutes in:
I think the only things I would do differently is use an old Toyota 4wd (pre-Tacoma), and put a basic ladder rack on top. But the mini-flatbed is a sick setup for residential. Maybe next year or the year after for me…
