@squidskc
Brodie, M5 Xjet or original, and did you get the replacement proportioner or just eliminate altogether??
M5. Iāve never had one of the originals. Replacement proportioners are like $15-20. Youāll want a spare set although we run two M5ās 2-3x a week or more and neither of them have needed replacing. Of all the proportioners, if youāre downstreaming most of the time, youāll use 2 proportioners or none at all.
Suds donāt equal cleaning, though I like decent amount just so I know where Iām at. Sell the mega crap machine on Craigslist and buy the m5 xjet, some decent soap and SH youāll be fine. Your 4gpm even in straight blech, the injector will only pull about 1% assuming the ratio is about 10-1, which most are or somewhere in that vacinity. For stucco and special situations, youāre going to need a stronger mix. Only 3 ways to get, pump sprayer or roof system or xjet. Just have to use the right tools for the job. Without, can get done, but itās often a struggle and much slower.
I mean i stay pretty low key most of the time, but this is a joke right? āCastigatedā? Me politely suggesting you search the forums, and giving you a couple of words to use, is ācastigatingā?
I spent probably 15 minutes on a VERY busy morning (just finished 12 hours of fire hydrant rinsing by myself), to do some quick searches, and literally sourced 2 products for you (wanted to make sure i was giving you accurate information), and answered some of your questions you had raised. The proper response in that situation is to say āhey thanks manā, not to get huffy because i politely suggested that you search the forums.
Hereās the thingā¦ when you dont search, especially on basic questions, you are causing other people to take time out of their (busy) day to repeat something that has been written a dozen times over the years.
I mean poor @Racer has been summoned three times so far (4 now!), when he spoon fed you the good stuff in his first post. āWhere do i source EBCā? Comon man. Thatās what Ask Jeeves is for!
And if you thought my earlier post was ācastigatingā, well then i imagine you will be forwarding this post to homeland security. Look man, im not mad at you, but this aint a sunday school facebook group. Got to roll with it a little better. You should do what i doā¦ each time before i hit the submit button, i say out loud to myself ānow remember, you are pretty much an idiotā. This keeps me grounded when IB calls me an idiotā¦ because wellā¦ i pretty much am.
Sorry, im a little more wound up than usual right now. As i was rolling up my last hose a little while ago, my left arm kept charlie horsing each time i raised itā¦ im sure i gave the EMTās on break a chuckle as I flailed my arm around a few times, trying to get it to work, before just grabbing all the hose and throwing it in the back of the truck.
Rick, Iāve been buying my bleach at the local pool supply house 4 gallons at the time. Until Brodieās post about bleach differences 55gal to pool supply, I had no idea about that. I also didnāt realize that the XJet would get me higher concentrations of solution. (@squidskc Brodie alluded to that some time ago and may have even suggested that one could perform a roof cleaning with the XJet?) NOR did I know that Dawn would make rinsing a nightmare. I had that happen to me several weeks ago when I had to go back and rinse with a brush a customerās home. In all fairness, I never expect the suds to clean. Their purpose is to hold the SH in suspension long enough to kill the organisms on the wall. DSing didnāt seem to suspend my solution(Elemonator and SH full strength), I kept adding more Elemonator and not seeing any noticeable difference. SO I 'll order an XJet this evening if it will suds the Elemonator and deliver a more concentrated solution. @tireshark 's suggestion that I buy a restoration product that only covers 150 to 200 square feet per gallon is cost prohibitive. Nonetheless, Iām truly grateful for his help.
As for the soot on the chimney (@gbattle no way to pump up spray that height), I quoted a home for next week based upon what Iād read here previously. Now Iām discovering that there will be extra costs that I hadnāt factored in. Oh well, school aināt always cheap, now is it? So Iām toying with the idea of a trailer setup but wanted to wait til Spring. An XJet might obviate the current need for the delivery of a more concentrated solution. Ithink Iāll try that airplane soot remover that @Justin_Treu found, and Iāll report back my experience.
Thank you all, and weāll pick this up with a successful ending when Iāve solved this conundrum.
Guys keep up with the castigating if he gets mad enough and has enough acid trip flashbacks he wonāt respond to anyone and things will be far out and groovy again (sorry, trying for flashbacks again)
Scooby snack
@Innocentbystander, I promised not to respond to your posts, and apologize in advance, but this is a good one. THANKS! Iām giving this one a ālike.ā Iāve been clean for over thirteen years, and sometimes I wish for a good flashback. Just sayinā.
This is a long threadā¦ which can be summarised on one sentence:
āBleach doesnāt clean sootā¦ small Victorian children doā
UPDATE:
Now I understand the metaphorical crickets I heard when I asked about sooty chimneys. Tomorrow I will clean the chimney that is featured in a previous post, but this has been my experience:
@Innocentbystander was correct, my equipment sucked. I upgraded to the M5XJet, and that has made all the difference. my stream flows with much greater pressure and volume. Thanks to @squidskc!
I have cleaned two chimneys since my post, and the problem was cleared up with Sodium Hypo,and my best results occured when I used the SH from the 55 gal drum that I BOUGHT TODAY. Thanks again to Rowdie! A local PW supplier only charges $150 for 55 gal delivered. interestingly they suggest adding a sodium hydroxide solution to the SH mix to improve efficacy. Has anyone else ever heard of this?
OK, back to the conundrum: I think that the problem I was facing was not necessarily soot. Most of the black stuff on chimneys appear to be the organisms that we kill with SH. I have enjoyed a great deal of success using SH and my M5XJet. I WILL confess that the Elemonator left me flat footed. It seemed that too much of my solution was ending up on the ground, but maybe it was the pool shock I was buying. Nonetheless, I used Cling-on from Power works this time.
Maybe one more application should do it.
Nice, thanks for the update. What was your mix ratio?
Straight SH 12.5 with 1 cup clingon per 5 gal, proportioner removed from XJet (should hit the brick at 1/2 strength).
I also did part of my roof with the same mix today. Will need more info before I finish that roof, but solution did a great job. I think Iāll start a discussion about roofs and the XJet.
I did a roof with an M5. My issue with it is the amount of solution put on the roof. Or the amount running off. Either way I just bought a 12v system.
I expect to go that route eventually. I hope for a compact system that will incorporate my 28ā water fed pole.
