Classic 4 tip cleaner
The force is on CASTERS meaning it goes side to side. Wheels back and forth only… I asked and he said yes it goes side to side…
Just like the classic,
I will do a path with classic
and a path with Force… To compare
may not be as good… i screw my self many times…
I called my guy at whisper he told me you will like it fine same as classic just wider… he had said take the casters off it will still float if you got 5gpm. He said it classic and Aqua Pro are about the same units…
You’ll be fine with any of them, just may have to adjust your walking speed. 4 nozzle bars are a recent event and we’ve been washing concrete forever just as clean.
Were you saying that you already had a 2 nozzle WW Classic?
If so, all you needed to buy was the 4 nozzle bar, instead of another whole unit. If it’s not too late, maybe you can cancel the order and save yourself around $485. It’s the same exact bar, just with two more nozzles…NOTHING different about the rest of the machine. You just have to buy a 4 nozzle bar and install it in place if the 2 nozzle. You can change from 2 nozzle to 4 nozzle, and back, at will.
was told by Whisper 4 tips does you NO GOOD unless you have a 8gpm system.
I know that with 8gpm the 4 nozzle bar is awesome…I just wanted you to know that, when and if you go to 8gpm you can just swap out the bar instead of buying a while new surface cleaner.
Find me a good 8gpm on wheels…
Found that North Star but it is 7gm…
I found this one but I would have to get a trailer 200 gallon build one up??
24 hp Honda it don’t say what brand of pump??
I thought you were looking for a hot water machine?
I have the exact machine Except mine is a skid. Why on earth do you want it on wheels though? That thing will weigh a ton and be a bear to wheel around. And with a 8gom machine you will definitely want it running from a buffer tank so the defeats it having wheels.
That’s a great price and even includes free shipping.
well I got to have the 200 gallon tank… all needs to be on a trailer to pull around don’t it? is the buffer tank same as a 200 gallon tank… I don’t really understand the buffer tank send a pic of your buffer tank set up…
If you move up to a 8gpm then you will need to attach it to a tank to act as your “buffer” between what your washer draws (8gpm) and the water spigot puts out (typically 4-5 gpm). You could get by with a 50 or 100 gallon tank but I sure like my 250. We always show up with at least 100 gallons of water and there are many times we wait on water because their spigot doesn’t out out enough to keep up.
A buffer tank is just a tank of water. It can be in any form you want.
If you do get a 8gpm machine, I HIGHLY advise you get it on a skid instead of wheels. That’s way too heavy of a machine to be wheeling around. Besides, it not only looks more professional, I think it is more professional because, you’re not leaving tire tracks all over your clients property.
you got to have your tank, engine, pump all together why not on a trailer rig have tool box…I got a plan
The skid unit gets bolted down… with the wheel unit if anyone really wanted it bad enough they could steal your unit way easier. Not to mention who wants to wheel around 180 pounds
Yes set it all on a trailer. What I’m saying is don’t buy your power washer as a wheeled unit. A 8gpm unit like that has no business on wheels in my opinion. The reasons sre endless:
1.) It’s too heavy to wheel around
2.) It needs to be attached to a buffer tank
3.) It’s more secure in a skid platform verses a wheeled platform .
4.) It’s much more professional to drag hoses verses dragging your washer
5.) It’s easier on your equipment
I would get the machines with wheels. Then all you have to do is get a buffer tank and put some wheels on it. It will be easy to roll both around while you wash. Don’t listen to these guys telling you to get a skid.
So you got to wheel it around and a 200 gallon tank around… I’m not the sharpest knife in the drawer but why not have both all together hoses tool box all together on a trailer… I found a company in Memphis they are building me a 8gpm… Some one Cougar who built the one I have now…
I believe that was sarcasm :wink:
The 24" of FORCE has come so till i get my new washer it will do fine.
Throw the wheels away and put a 90 degree elbow at the swivel
now hold the phone let’s see how it does in action… I just finished a BIG house yesterday wished id had it yesterday…
What does the 90 degree elbow do for me?
